Mobian phone app update 2-14
I am running mobian-pinphone-phosh-20210202.img
Today I received a system update through the phone GUI and a calling app update. Huge improvement on call quality.
I have postmarketOS edition PinePhone.
(02-14-2021, 11:19 AM)mw4jet Wrote: I am running mobian-pinphone-phosh-20210202.img
Any chance it works with bluetooth calling?
No, bluetooth does not work with calls, making a call though contacts does not work either, you have to actually input the phone number. You can text from the contacts button though.
(02-14-2021, 12:18 PM)mw4jet Wrote: No, bluetooth does not work with calls, making a call though contacts does not work either, you have to actually input the phone number.  You can text from the contacts button though.
Sorry if I don't understand correctly your comment.
Do you mean that a call from the Contact application could not be done ? I'm surprised because I can make a call using the contact list.
gnome-call seems to be broken since last update ...
can't place calls from history or cmdline using gnome-call -l
but as stated, it works from dialpad, it also works from xdg-open (and from the contacts app)
it is a minor issue (it seems to be a memory allocation failure so it should already be fixed by now)
I confirm a problem.
I can't call back from the top menu when I see a "missed call". When I've try to open the Call application a red message said "... : No voice-capable modem".
When I use Contact to make a call, all is working.
On my phone I can go to Text Message from contact page in Contact App, but to make a call, not all contacts work. (I don't want to start calling everybody in my list to know if others work). I did get one to call from the phone icon in the contact app.
My Bluetooth is acting up. I listen to audio on VLC and after 5-7 minutes it just disconnects.
issue seems to be fixed in the last gnome-calls update Smile
(02-15-2021, 05:58 PM)mw4jet Wrote: My Bluetooth is acting up. I listen to audio on VLC and after 5-7 minutes it just disconnects.
That's probably because VLC doesn't prevent the phone from going into sleep. Lollypop does, though.
  Mobian repository status henrythemouse 16 8,743 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,001 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,994 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,819 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,887 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,897 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 630 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,017 06-19-2023, 03:02 PM
Last Post: vusra
