h264 hardware encoding on Pinephone?
Hi
Is h264 hardware encoding available on the pinephone? I looked at the status of Cedrus driver and it seems to me that only hardware decoding is working not encoding.
Am I wrong?
The A64 CPU will for sure allow for H264/H265 encoding and decoding, so it's just kernel support...
I spent a while checking out Mali 400 kernel driver support, but I am not sure the Mali 400 even handles the encoding/decoding - this may actually be something done by some other part of the A64 - i.e. in the video engine: https://www.cnx-software.com/wp-content/...iagram.jpg
If the support matrix in project Cedrus is anything to go by, it seems only partial support is achieved: https://linux-sunxi.org/Cedrus#Supported_codec_matrix
It seems like the work has been left in a nice place to pick up from though.
(02-13-2021, 05:13 PM)barray Wrote: The A64 CPU will for sure allow for H264/H265 encoding and decoding, so it's just kernel support...
Yes, it's what I noticed also, there was quite some work on this but things like h264 encoding or more features for the h264 decoding were not implemented.
Anyone is working on this? If all Pinephone owners would crowdfound these features it would be nice I think.
Not just PinePhone, but also PinkBook (not PineBook Pro) and PineTab use the A64 - which seems really only half implemented in terms of silicon support. If anything ever becomes of the PineCom, the expected processor to use would be the A64.
I really wonder what is involved in such an engineering effort and how it could be possible for people to pick up from where they left off? The boards for testing on seem pretty cheap anyway... https://pine64.com/product/pine-a64-1gb-...46c16e2e66
If I could find out exactly where the current code is and how to work on it, could make for an interesting project.
  PinePhone - boot from microSD laserpyramid 6 538 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 339 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 228 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,876 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,776 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 599 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,333 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 490 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,672 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,935 12-04-2023, 02:14 AM
Last Post: Peter Gamma
