Alternative Compatible Cases for the PinePhone?
I just bought a pine phone but I forgot to add the case to the shipment.  I went on the website to buy a case and the shipping is more than the case itself.
I'm wondering if there are other name brand cases that would fit this phone, or be adapted to fit this phone (like cutting stuff out, etc).  Or are there generalized cases out there where you "cut to fit" type style.
I would love to have your feed back.  Thank you.
(02-12-2021, 02:19 PM)Trizzle Wrote: I went out and searched all over the internet for a compatible case and I found one!
Phone:
Xiaomi Poco M3
The layouts and dimensions are extremely similar and as far as I can see, if somebody were to get a Xiaomi Poco M3 case for the PinePhone, it would fit perfectly.  There will be a huge hole spot on the back of the case but that shouldn't matter.
Thoughts, ideas, questions, concerns?
**UPDATE**
I looked up cases on the Xiaomi Poco M3 phone and apparently I was incorrect about the rear camera placement.  I'll have to look more into other compatible cases.
I'm afraid such a case won't be very suitable even if the size fits. It looks like the headphone jack is differently placed and the buttons on the side seem to be lower, so those probably won't fit the Pinephone.
Not much help, but you wouldn't have been able to order the Pinephone together with the case anyway due to shipping restrictions with the battery of the phone, so no missed opportunity Smile
  Case for Pinephone totilele 13 7,214 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 635 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,163 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 514 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,021 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,289 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,024 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,368 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 634 08-04-2023, 10:47 PM
Last Post: jnpine
