Mobian Development Environment - system requirements
Hi all,
I just got my brand new PinePhone and I have spent a lot of time searching what distro to start doing development for.
Mobian Project seems to be the best described project in terms of development and how to obtain the source code.
The only thing missing from all distro's is what system requirement is needed to do a proper hardware/VM setup to ensure
enough RAM and Disk space to both host the build source code and to do the software compilation? And what Debian OS version
to use to make sure necessary build tools will be available for the process of building.
So my question is:
Where can I find info on DISK/RAM/OS requirement for physical machine and also for VM/Docker if this is more feasible?
I believe a VM/Docker approach would be the best way to kickstart the development process...
My stationary is a Gentoo box so if any one has a pretty good setup for doing Mobian development on this platform I would like to know whats and hows to this approach too :0)
/666
(02-12-2021, 05:32 AM)mgronbak666 Wrote: The only thing missing from all distro's is what system requirement is needed to do a proper hardware/VM setup to ensure
Since Mobian is less of a standalone system but more a flavor of Debian you should definitely search at debian.org.
The links under documentations at https://www.debian.org/devel/debian-installer/
and
https://www.debian.org/doc/manuals/maint...ex.en.html
Mai be helpful but I don't know.
  Mobian repository status henrythemouse 16 8,578 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,854 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 116 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,901 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Errors when start the system kubussz 2 532 11-21-2023, 11:07 AM
Last Post: kubussz
  System won't suspend due to suspention notification user641 6 1,322 09-24-2023, 05:47 AM
Last Post: user641
  What actions needed to keep on mobian testing user641 3 1,770 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 617 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,808 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,874 07-09-2023, 01:37 AM
Last Post: vusra
