Changing Mobian PIN to use alphanumeric pin?
Hello all,
I have been pondering the actual security of using a numeric pin for the lock screen.. Even with a 10 digit pin it can easily be cracked in 2 mins with the right setup. Is there a way to use an alphanumeric pin on Mobian. Thanks.
(02-06-2021, 07:07 PM)jabadahut91 Wrote: Hello all,
Or better yet have a numeric pin for login, and something else for ssh etc...
Well I have ssh setup with a 4096 bit encryption keys and a 25 char password, but I want to also have the pin be alphanumeric. I'm more worried about if someone gains physical access to the phone while already powered on.  Is this not possible?
(02-06-2021, 08:48 PM)jabadahut91 Wrote: Well I have ssh setup with a 4096 bit encryption keys and a 25 char password, but I want to also have the pin be alphanumeric. I'm more worried about if someone gains physical access to the phone while already powered on.  Is this not possible?
Did you disable passwords in ssh?
yes, the key has to be provided alongside with the paraphrase for it. So my issue isn't on the ssh side it's on the lock screen. I want to be able to at least make it a little harder to break past the lock screen if the phone was obtained after the disk has been decrypted. For instance let's say I was mugged carrying it - the power would still be on, I might not have access to get to the ssh quickly enough, and I would want the thief to not be able to take it to a tech savy person who could rig up a simple brute force to bypass the pin on lock screen.
(02-06-2021, 07:07 PM)jabadahut9 Wrote: ...
As far as I know this is a pheature of phosh! How about adding a DM on top, say lightdm?
Numeric PINS are pathetic security, especially if you use them for on-disk encryption as well.
I will try that that. Thanks for that idea!
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,949 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 17,719 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,237 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No sound after Mobian upgrade arbocenc 1 764 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,112 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,362 09-24-2022, 08:01 AM
Last Post: dante404
  PinePhone running Mobian - Malware extraction? names_fold 1 1,633 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 2,091 01-17-2022, 02:18 AM
Last Post: bcnaz
  Assists for running Mobian my PinePhone gilwood 0 1,596 01-01-2022, 04:38 PM
Last Post: gilwood
  ? vpn or tor for mobian rvh 9 7,220 12-02-2021, 05:58 PM
Last Post: b7l3wui26r
