Alpine on RockPro64
Some time ago, I wrote a small script to build an Alpine image for the Macchiatobin platform. I had some time a couple of weeks ago to see if I could also build something for the RockPro64, and it turned out to be way easier than I thought.
I don't have any images published, and the script itself is still pretty rough around the edges, but it does produce a 40-ish MB image that will properly boot Alpine, so I figured i would share it. Note that I'm building this specifically to use the RockPro64 as a router (using an Intel X550), so the kernel is pretty slimmed down and huge chunks of non-router functionality have been removed.
You can find everything in the hosted repository: https://git.sr.ht/~mutemule/alpine-router-aarch64
(Turns out that the only real tricky part was that you need the specify the serial console to use with `earlycon`, and once that was done, Alpine basically boots just fine. Everything else I've done is just to strip the kernel down to be what I want it to be.)
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 445 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 697 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,598 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,262 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 82,976 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 575 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 933 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,566 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,640 01-03-2023, 06:53 PM
Last Post: raph
  hello i want to drive an edp screen with my rockpro64 hannescam 0 744 10-20-2022, 01:22 PM
Last Post: hannescam
