How to return to "home screen"
Hey all, received my PinePhone today with Manjaro ARM/ KDE Plasma. I'm wondering how I can return to the home screen. Everytime I open an application, the only way I know to return home is to power off the phone and on again.. Surely there is another way?
Hey, I got the same problem, you have to update (with Discover), then it will work well.
(02-01-2021, 02:15 PM)hiddenpotato Wrote: Hey all, received my PinePhone today with Manjaro ARM/ KDE Plasma. I'm wondering how I can return to the home screen. Everytime I open an application, the only way I know to return home is to power off the phone and on again.. Surely there is another way?
tap the leftmost button under the app window, and the app window will shrink. Now tap the middle button on the screen bottom and you have the home screen.
Swipe down on the keyboard if it's active and the 3 bottom buttons will be accessible. Smile
It's weird that the nightly image gives you Manjaro+Plasma setup, including username, PIN, and TZ, along with a little "here are the buttons" prompt, but the beta releases (which is what comes shipped on the Pinephone) do not. Instead, they come preconfigured with a generic username, a default PIN, and you miss the setup prompts.
Consequence: questions like these, and presumably a number of portable Linux computers running default usernames with the numeric password 123456.
I just received my PPP yesterday... and I bricked it within 12 hours. Well, I corrupted the eMMC image. I downloaded & flashed the 2220301 Manjaro / Plasma image onto a microSD card and can boot now... but whenever I start an application... I cannot return to the home screen? I am stuck long pressing the power button and restarting. Kinda slows things down.
Not sure that "update" applies here since I downloaded today's image? WhaddamImissing?
(03-01-2022, 10:07 AM)steve2267 Wrote: I just received my PPP yesterday...
This is PinePhone section, I'd recommend to post to the PinePhone Pro section Wink
https://forum.pine64.org/forumdisplay.php?fid=179
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
Here is the Pinephone Pro link that addresses this issue:
https://forum.pine64.org/showthread.php?...#pid107522
For anyone with a Pinephone, I had the same problem and missing quick settings / status bar on dev image / unstable branch, posted issue on Manjaro forum then found bug reports / possible fixes:
https://forum.manjaro.org/t/plasma-mobil...app/104603
No issue with stable branch, can downgrade on unstable, otherwise hopefully fixed versions hits the unstable repos soon.
  screen brightness Uturn 1 604 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 590 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 809 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 3,798 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,855 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,026 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 944 07-04-2022, 11:42 AM
Last Post: tuxmain
  Manjaro Welcome screen landscape JohanB89 2 2,123 11-12-2021, 01:13 AM
Last Post: acrux
  KDE Plasma Mobile screen scaling Uturn 1 1,761 10-29-2021, 06:59 AM
Last Post: Uturn
  How to remove Manjaro Phosh lock screen password? Avisando 4 3,781 10-28-2021, 04:20 AM
Last Post: Avisando
