Mobian PIN changed after update!
#21
I stumbled on the Mobian Release Notes. I went through the process of reloading Mobian and the install instructions states that the screen unlock code is set to "1234" the same code as on my luggage.
All is well now.
  1. Restart your device: Sometimes a simple restart can resolve temporary issues. Try rebooting your device and see if the default PIN starts working again.
  2. Reset the PIN: If a restart doesn't work, you may need to reset the PIN. To do this, you can try the following steps:
  • Boot your device into recovery mode (the process may vary depending on your device).
  • Look for an option to reset or clear the PIN or password.
  • Follow the on-screen instructions to complete the reset process.
  • Once the reset is done, you should be able to access your device with the default PIN.
Cool Heart
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,935 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,233 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No longer waking up from sleep after recent update gamerminstrel 2 1,295 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  No sound after Mobian upgrade arbocenc 1 760 11-28-2022, 11:02 AM
Last Post: arbocenc
  no sdcard boot and manjaro update failed Gwen 3 1,397 11-27-2022, 07:56 AM
Last Post: fxc
Exclamation No wIfI after Mobian update crakabeats 3 2,109 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,348 09-24-2022, 08:01 AM
Last Post: dante404
  update kills keyboard ludgate 1 1,173 05-18-2022, 12:43 AM
Last Post: programmin
  PinePhone running Mobian - Malware extraction? names_fold 1 1,629 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 2,084 01-17-2022, 02:18 AM
Last Post: bcnaz
