microsoft teams install problem
hai  i am Jip ,  not very handy with computers, but do not want to support the big companys that make the rules.  I feel a little lost here with my computer and do not know who to ask for help.  i try to install teams from microsoft for my kids school lessons...   but i fail somehow.  i installed  snapd and restarted after that i tried the command
sudo snap install teams-insider
on terminal   but  it will not accept the command....
earlier it accepted the command, but i could not type my password.
what do i do wrong? Huh
the real issue you're having is that snap package only supports AMD64, not ARM64: https://snapstats.org/snaps/teams-insiders
Your best bet is likely to use a chromium-based browser and use Teams through that. Honestly, having to use teams on multiple platforms, this is the way to go, to avoid Teams' very terrible custom/annoying notifications and make use of the system-wide notification system.
You could try this version made for RPi: https://snapstats.org/snaps/teams-for-linux but it's supported architures only include armhf and amd64, so some work may be required to get it working well on the PBP, without the need to install armhf libraries. the devs offer an arm64 deb file you should be able to use: https://github.com/IsmaelMartinez/teams-..._arm64.deb
for anyone else using arch/manjaro, this is also available in the aur: https://aur.archlinux.org/packages/teams-for-linux/
https://docs.microsoft.com/en-us/microso...ents#linux but no ARM Sad
I'm shocked they have Teams at ALL for Linux. I've been using it on my laptop (Dell) with Pop_OS for the past year. It's been... Ok I guess. It's still missing a lot of features that the Windows/Mac clients have.
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,824 08-03-2023, 03:30 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,856 06-01-2023, 10:58 AM
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,691 02-21-2023, 01:49 AM
Last Post: repa
  Use SD to install new OS over pinebook debian Rudy558 9 10,644 09-25-2022, 01:19 AM
Last Post: jackwilson
  MiniConda Install Issues nixyhustle 0 780 09-16-2022, 10:06 PM
Last Post: nixyhustle
  Does anyone know how to install levinsboot on pbp? computerc 0 619 09-05-2022, 03:52 PM
Last Post: computerc
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,409 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Problem SD card willahughes 1 1,547 03-22-2022, 09:27 AM
Last Post: jiyong
  very strange .pptx highlight color problem stozi 0 1,153 09-02-2021, 02:50 PM
Last Post: stozi
Tongue Hello my frend. How to fix my boot problem? carinosa 6 5,431 07-04-2021, 04:01 AM
Last Post: jiyong
