Batch #2 - DOA Pinecil?
While I opened a ticket to get an official answer to this issue, I'm also posting here in case there is a quick fix / known issue.
I received today my Pinecil from the 2nd batch. When plugging it to any power source (tried a few PD USB-C, and 12V DC barrel, or from the computer) the screen either stays black, or for about 1 out of 3 plugging events I'm getting a "random dots" pattern
[Image: SVb67iG.jpg]
Reading around in the forum / wiki:
- I updated the firmware to the most recent one (following http://forum.pine64.org/showthread.php?tid=12803 as the MASS_ERASE error was present for me too)
Same issue after successful update. Pinecil is detected in DFU mode as you would expect.
- I can also confirm that this device is making an annoying rattling noise http://forum.pine64.org/showthread.php?tid=12859 that seem to be coming from the DC barrel / USB-C side of the device. Opening it up did not reveal anything loose there, but confirmed the location of the noise. Not sure if normal (but slightly annoying to say the least) and unlikely to be linked to my issue as both DC barel or USB-C powering seems to result in random dots pattern.
I will update that topic when I'm hearing some news from the ticket, but hopefully someone else got the same issue and have a fix for it.
Update from the opened ticket: it was indeed DOA, this unit is getting a RMA.
If you are having the same issue and ended up finding that forum post your best option for now is to open a support ticket on the "Order Support" section of the website https://desk.zoho.com/portal/pine64/home
Meanwhile if anyone want me to check anything specific inside to understand what the issue is before I have to send it back I will gladly try to do my best to have a look.
(01-27-2021, 04:57 PM)emc2cube Wrote: Update from the opened ticket: it was indeed DOA, this unit is getting a RMA.
Please do so, product team has high interest to know the failure cause and keep improving the Pinecil.
  Connecting a power supply to the Pinecil jon_bondy 1 334 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 754 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 352 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,180 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 643 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,267 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,528 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,422 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,224 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,240 11-06-2022, 02:43 AM
Last Post: River
