Specifications of fan connectors?
I'm not an expert in connectors but wanted to connect a usual 3pin non-PWM fan to my RP64. However, I can't find information about the connectors for the fans on the RP64 board. Do they conform to the following?:
    GH 1,25mm
Many thanks in advance.
(01-15-2021, 11:44 AM)kuleszdl Wrote: Hi,
    GH 1,25mm
2 pin PH connector, please noted that you need to use 12V fan.
Thank you @tllim - I assume it is PH 2.0mm then, right?
FTR: PH 2.0mm worked perfectly. I now have more "headroom" for the cables.
I also found that 4pin PWM fans *do* work as well, but regulating them cannot be done as well as with the regular 3pin fans. Actually, there is one 4pin PWM fan that has a depth of just 10.8mm (I didn't test it myself):
Akasa Slimfan, 80mm (AK-FN076)
My current setup runs with the following fan (15mm depth):
Titan TFD-8015M12Z
It is relatively quiet even at full power.
  PCIe port specifications MisterA 0 1,833 12-11-2018, 02:55 AM
Last Post: MisterA
