Sudden Pinebook Pro boot problems
My Pinebook Pro has suddenly developed boot problems.
I have Danielt's Debian installed on emmc and it was working fine until today.
Now when I press or hold the power button nothing happens.
If I insert a MicroSD card with a distro installed on it and press/hold the power button the following happens:
1. I get a red light
2. Next I get a green light and the PBP boots the image installed on the emmc rather than the image on the MicroSD card.
Any Ideas on how I can fix it so I can:
1.boot from emmc without the presence of a MicroSD card.
2. boot from SDcard when one is installed.
Hi ndp
I'm also using Daniels Debian-Installer.
I noticed that since a couple of days, the boot process takes around 30-40 seconds instead of the usual 10-20.
Have you been able to get any console output from your install?
(01-13-2021, 04:18 AM)Tharadash Wrote: Hi ndp
I at some point have seen my PBP also increase its boot time. Turned out the original MODULES=list in /etc/initramfs-tools/initramfs.conf got changed to MODULES=most, which is Debian's default. Probably the whole file got replaced during one of the updates, because I usually also set KEYMAP=y instead of its default KEYMAY=n and that was reset too. I run kernel 5.8.5 built with pbp-tools script, and with it I currently have set MODULES=dep. Works fine and boots pretty quickly.
P.S.: I also have MrFixit's v2.0 u-boot on eMMC and I've removed maxcpus=4 from /etc/default/u-boot together with the snippet in /etc/tmpfiles.d/ that re-enables big cores during boot.
This message was created with 100% recycled electrons
I had no joy fixing this boot problem, so I booted of a MicroSD running MrFixit's Debian Mate image and then re-installed to the eMMC using Danielt's Debian installer.
This time I installed the default "bullseye" version rather than the "buster" version that I specified on the previous install.
So far, the new bullseye install seems snappier and more stable.
  Pinebook Pro Initial Impressions kunger 442 583,376 54 minutes ago
Last Post: dachalife
  looking to buy one pinebook pro (mainland China) duanduan 3 2,228 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 372 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 275 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 267 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 203 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 628 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 694 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 746 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 272 01-16-2024, 09:17 AM
Last Post: jbradley419
