Pinephone back plate / case idea for switches
Question
I am interested in purchasing a pinephone but the one thing holding me back is the dip switch location.
My idea at first was to cut out the back place to have easier access but the switches are tiny, so I cam up with a newer idea.
Why not make a back plate or case that not only allows access to the kill switches, but also enlarges them so it is more practical and convenient? Yes of course the back would stick out more but it is something we could get used to by necessity?
Maybe this is easier said then done but I would love to have this option. Thoughts?
I have been thinking about something similar. I think one problem might be that the switches are really close to each other. I still don't think this would be impossible. If I had a 3d printer I would try making this.
(01-10-2021, 02:04 AM)bartaco Wrote: I am interested in purchasing a pinephone but the one thing holding me back is the dip switch location.
What if you accidentally glide over the switches while the phone is in your pocket?(白目)
母語は日本語ですが、英語も喋れます(ry
I'd be happy with a back cover that has a window that opens to expose the switches, with a tool attached to the inside of the window for use on the switches.
OR
Perhaps a single switch that slides side to side over the dip switches, clicking into place above each switch; the switch can be pushed up and down, springs return it to center. A locking mechanism to prevent pocket activations.
I would be worried about dust and pocket lint. I have never had an issue taking off a cell phone case, obviously the small switches are less than Ideal, but at least you have options for set up!
  Back plate. jbloodwo 0 8 1 hour ago
Last Post: jbloodwo
  Play along - create a PinePhone keyboard Luke 186 51,842 9 hours ago
Last Post: CharlieGordon
  Pinephone with Google Fi SIM riotsu 5 1,552 01-03-2021, 01:25 PM
Last Post: rocket2nfinity
  3D Printing a Pinephone Back Cover sundog 19 5,293 12-16-2020, 08:03 AM
  USB-C Dongle and Branded Case backs hiimtye 11 1,598 12-16-2020, 07:38 AM
Last Post: nas
  Pinephone charger - does LED change color? Zebulon Walton 1 252 12-15-2020, 12:38 AM
  3D Printed PinePhone stand simoni 13 1,508 12-10-2020, 10:15 AM
Last Post: patrickmollohan
Heart PinePhone / Pine Tab dock or PineBook hockleyj 6 2,657 12-10-2020, 03:47 AM
Last Post: sbl
  Thermal imaging solution board for the PinePhone board jnpine 2 394 12-04-2020, 04:27 PM
Last Post: jnpine
  Soft vs. hard Pinephone case? Zebulon Walton 6 1,555 11-11-2020, 01:34 AM
Last Post: janw
