Debian Bullseye installation
Hello, extremely new to Linux in general, had lots of help in figuring things out with my PBP. Wanting to try out Debian on my SD card and ran into some troubles. Got the installer script completed, but when I load up again I get a black terminal screen, with a login/password. I set up my username in the install but it did not ask me for a password. Is there a default for this? Unable to load up any kind of start screen, so maybe something went wrong with the script?
which install method did you use? Did you install using firmware.img/partition.img using the official Debian unstable installer?
I used the Daniel Thompson Git Hub link
https://github.com/daniel-thompson/pineb...-installer
I saw a YouTube vid on it and it looked pretty straightforward. I’m guessing that’s not the normal way to do it?
Well, the official way is the one described in the README:
https://d-i.debian.org/daily-images/arm6...ble_images
Success with this method varies, though. I haven't tried it for a while, but I assume once bullseye gets released it should definitely work. Smile
Personally, I recommend doing the installation as described in my blog (it uses stable OS + current mainline kernel, but you can do the same approach to install unstable if you want):
https://www.kulesz.me/post/150_devuan_pinebookpro/
If you installed using Daniel Thompson's installer there is a separate thread for this method here:
https://forum.pine64.org/showthread.php?tid=8487
  Debian on Pinebook Pro u974615 7 968 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 5,899 03-16-2024, 03:09 PM
Last Post: michel_luc
  install debian on pbp jsch 7 4,020 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,333 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,012 07-15-2023, 02:58 PM
Last Post: u974615
  HOW TO create a installation USB with ... (see below) Ice-O-Star 1 1,141 01-06-2023, 01:02 PM
Last Post: DrYak
  My installation guide starting from messed up eMMC Besouro 0 867 12-19-2022, 01:01 PM
Last Post: Besouro
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,268 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,319 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,025 10-19-2022, 03:09 AM
Last Post: alpopa
