App dev on mobian
Not sure where to post this, but I'm having trouble getting my app working on mobian, works ok on a desktop.
I'm making a geocaching app for mobian and it's mostly working except when clicking on caches on the map, double clicking to zoom in doesn't work either.
A current build can be found here: http://files.evilbunny.org/geocachingapp.deb
The app is far from finished, so far you can login and download caches and move the map about by clicking and dragging. If you run it on a desktop you can click on a cache and it outputs to stdout the cache ID, pinching to zoom on mobian doesn't seem to work either.
The signal to detect clicks on the markers is "button-release-event", I'm not sure if this signal is being sent to apps based on touches, and libchamplain doesn't seem to track/pass on "clicked" events to marker objects.
Any help would be much appreciated.
  Mobian repository status henrythemouse 16 8,724 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,988 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 128 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,986 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,803 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 632 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,875 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,893 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 628 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,009 06-19-2023, 03:02 PM
Last Post: vusra
