Feasibility of mining crypto on RockPro64?
Is there any seemingly straightforward way to mine any form of crypto on the RockPro64? I have one laying around doing nothing so I figure if I can at least get it making a few pennies a day I might be able to recoup my costs of purchasing the thing.
Would a USB ASIC miner work on this? Or would it be possible to plug in a GPU into the PCI slot to mine off that?
v0.10 beta for ARMv8-A (ARM64) : Monero (reddit.com) had results on a Pine64 but is it compatible with the RockPro64? How would I install it?
I have the same interest
Not very feasible. I'm mining wow and only getting about 250 h/s. So far it comes to about 5 cents a day. You can get an app called xmrigcc.
It works best with Ubuntu (armbian focal). If you would like to try, follow the steps below:
1) apt-get install wget proot automake autoconf pkg-config libcurl4-openssl-dev libjansson-dev libssl-dev libhwloc-dev hwloc libgmp-dev zlib1g-dev make g++ git build-essential cmake libuv1-dev libmicrohttpd-dev gcc-7 g++-7 curl nano clang libuv1-dev -y 2) git clone https://github.com/Bendr0id/xmrigCC.git 3) chown -R $USER:$USER xmrigCC 4) cd xmrigCC 5) cmake . -DCMAKE_C_COMPILER=gcc-7 -DCMAKE_CXX_COMPILER=g++-7 6) make 7) cp src/config.json . 8) nano config.json 9) sudo sysctl -w vm.nr_hugepages=1280 10) ./xmrigDaemon 11) enjoy
Maybe we can figure out a way to push the limits on these devices.
  Installing Wifi drive for the RockPro64 John45595 0 304 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 751 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 681 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,240 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 885 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,317 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,816 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,642 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,017 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,782 10-21-2022, 07:44 AM
Last Post: rapier1
