Rock64 v2 as Openmediavault server - buffers / shutdown problems
For Rock64 Ver2 (1GB ram), I installed OMV using Guide: Installing OMV5 on Raspberry PI's, Armbian SBC's, & i386 32-bit platforms: Link: https://forum.openmediavault.org/index.p...platforms/
Thanks to the guide, it's easy to install & starts working.
However, I can not shutdown. With either webpage shutdown command OR SSH shutdown command or connecting keyboard & monitor and on consol, in all three cases - it restarts instead of shutdown.
 2nd try:
I install the same thing again on another SD card but the same problem - can not shutdown [Image: 2639.png]- always reboots.
Transfer speed from Windows 10 to OVM is about 90 to 95MB/s in write & 65 to 70 MB/s (USB3 external HDD)
Sharing video files from OMV to Kodi & vlc on firestick 4k, NO buffers. works great[Image: 263a.png].
Now,
I tried from OMV: https://github.com/ayufan-rock64/linux-build/releases/ - It works & shutdown too[Image: 263a.png].
Transfer speed from Windows 10 to OVM is about 95 to 105MB/s in write & 75 to 90 MB/s (higher than previous installs)
BUT, while sharing video files from OMV to Kodi & vlc on firestick 4k, buffers a lot & it's unwatchable[Image: 2639.png].
How I can achieve the best of both worlds?[Image: 1f914.png]
(12-27-2020, 11:39 AM)helpmerock Wrote: For Rock64 Ver2 (1GB ram), I installed OMV using Guide: Installing OMV5 on Raspberry PI's, Armbian SBC's, & i386 32-bit platforms: Link: https://forum.openmediavault.org/index.p...platforms/
 2nd try:
Now,
I had the same trouble with my Rock64 using Armbian_20.08.1_Rock64_buster_current_5.8.6.img.xz .
The shutdown worked fine.
Once I installed OMV5 with:
     sudo wget -O - https://github.com/OpenMediaVault-Plugin...er/install | sudo bash
the shutdown still worked fine.
It all went downhill when I installed the lastest kernel (5.9.14).
Shutdown keeps restarting.
I backed out to the previous kernel (5.9.11) and the shutdown seemed to work again.
I started over, this time starting with the newer Armbian_20.11.3_Rock64_buster_current_5.9.14.img.xz .
Then installed OMV5 using the same process as above.
Now, everything is working perfect.
Shuts down without restarting.
Thanks, Dano for your reply,
I'm not sure which kernel I used to install Armbian as I deleted the original files but I remember that I downloaded 2nd time on Dec. 22, 2020. Is this 5.9.14 updated afterward?
Also, I checked in system information & it is 5.9.14.
I don't want to install again & do all configurations.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 288 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,337 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,695 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,157 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 337 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,894 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,533 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,111 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 762 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 957 10-07-2022, 07:50 PM
Last Post: rookie_267
