SMS notification inconsistent and Wifi issue (waking up?)
Anyone know about notifications?
If I use King's Cross terminal to do:
systemctl suspend
then when a text message comes in I seem to get only a blue blinking LED due to the King's Cross command notification success (from when I suspend). So no audio warning for received SMS.
Even though I have Settings - Applications - King's Cross - Off for everything!
It seems as though the King's Cross 'Command Completed' notification just has the flashing blue LED (no sound) or the fact it is in the queue prevents the Chatty 'New Message' notification jingle to come through....
sudo pkill chatty post means you don't get notifications until you open Chatty (I think).
I'll let the phone autosuspend and see how it goes (with A sudo pkill chatty pre for now).
Note I managed to just get the modem turn on without a blue blinking LED or an jingle so not clear what is happening.....(when incoming SMS).
How is the wifi with your script ? Does it help ?
(01-21-2021, 02:28 AM)as400 Wrote: How is the wifi with your script ? Does it help ?
@as400
I'd say more testing needed, but with wifi off, then waiting for suspend / systemctl suspend, whenever I've sent a test SMS (even if the notification failed), whenever I turned wifi on I had no problem - sometimes it was slow to connect but I haven't had the weird behaviour observed previously.
I'm trying it now with wifi on, then suspend. Seems ok, too.
I'd say so far so good and seems to be the right solution to the right problem (for wifi).
Happy to hear from others!
Thanks for the systemd suggestion, I've learnt something new.
  New keyboard issue sandspur 29 12,407 10-05-2023, 02:27 AM
  System won't suspend due to suspention notification user641 6 1,421 09-24-2023, 05:47 AM
Last Post: user641
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,888 07-18-2023, 08:54 AM
Last Post: junelung
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,200 07-17-2023, 01:49 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,227 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 1,466 01-12-2023, 03:06 PM
Last Post: user641
  Possible solutions to the battery draining issue? 3x5co 5 2,405 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 5,311 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,855 06-02-2022, 07:16 AM
Last Post: arkadione
  Problem with wifi kubussz 0 873 04-02-2022, 12:57 PM
Last Post: kubussz
