PineTime runs only with 3.3V via pogopin
Question
I have tried to update my pinetime with pinetime-updater and a raspbery pi. The script ended fast, without succes.
Now the watch is not starting or loading anymore. It only starts with pin 3 and 4 connected with the 3.3V pin and ground pin of the pi. Then it works fine (screen, bluetooth and gadgetbridge).
Ideas?
@jvw1954 I am by no means an expert with this device, I'll try to get some persons in here that are.
A few things to try:
* Try flashing a known good image before doing anything else - I can personally say that JF's latest release works well.
* Hold down the power button for a long time - many of OSes recognize this as a request for reset.
* A battery disconnect and reconnect (you might need need to de-solder the battery from the pad). It's a pain, but this will ensure the device is fully reset.
I've just checked the PineTime schematic [1] for possibilities of reasons why you wouldn't get power from the battery, but unfortunately it's not so clear. You should test the following if you have a voltmeter and post the results (with and without pogo pin power applied):
* TP21 (5V) to TP22 (GND)
* TP23 (~3.3v to ~4.2V) to TP24 (GND)
* TP25 (3.3V) to TP26 (GND)
That should tell us if you're seeing battery power and whether the regulator is working correctly. If you've got a busted regulator, I would expect to see TP25 to read 0V when measuring just the battery is connected. That would in theory explain why bypassing it would bring the CPU up.
I would suggest to the circuit designer to make some modifications:
1. A diode on pogo pin inputs to prevent somebody accidentally connecting 5V to a 3.3V line, or vice versa. We're talking a few cents to save tonnes of potential headaches.
2. Throw a diode in front of the 5V input, USB can really vary as high as 6V (and as low as 4V) if you're unlucky. Depending on U14ME6206, you could even throw the 5V USB input through the same regulator as the batter (using some diodes to block battery and 5V from one another). The regulator would then be powered from the highest voltage source, which should be USB at ~5V.
3. Use a standard connector instead of pogo pins, it's much better than some temperamental connection. I believe they do JST connectors at the right size and with a some slight layout changes there will be enough space in there (bring it out away from the side of the watch wall).
[1] https://files.pine64.org/doc/PineTime/Pi...191103.pdf
Now that your device has started with the pins connected to the pi, does it still runs if you disconnect them?
Maybe pinetime-updater failed for whatever reason, and the device was stuck in programming mode. I guess that connecting the pins to the pi issued a reset, and you should be good to go.
If it stops when it's not connected to the pi, maybe the battery is empty and that it works because the pi is feeding power to the pinetime? Have you tried to charge your device?
If you have a stlinkv2, you can try to follow these instructions to flash your device using openocd.
Working on InfiniTime, the FOSS firmware for the PineTime: https://github.com/InfiniTimeOrg/InfiniTime
Mastodon : https://mastodon.codingfield.com/@JF
Twitter : https://twitter.com/codingfield
Matrix : @JF002:matrix.org
  PineTime at FOSDEM jmlich 5 797 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 249 01-31-2024, 11:57 AM
Last Post: tynstar
  PineTime and Amazfish on Ubuntu Touch jmlich 1 753 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 13,871 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,376 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,237 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 6,799 02-11-2023, 09:30 AM
Last Post: alexmitroff
  PineTime beginner MV1791 2 2,205 01-09-2023, 11:52 PM
Last Post: Canyonless
  Struggling to detect Pinetime over bluetooth John45595 0 1,175 11-20-2022, 11:06 PM
Last Post: John45595
  PineTime Dev Kit for sale igor.bljahhin 2 3,220 10-19-2022, 05:34 AM
Last Post: peatord
