disable passcode lock screen?
I would like to disable the passcode lock screen. Takes way to long to access the phone and I have zero worries over 3rd party access to the device.
I have looked around the filesystem for lightDM, phosh, phoc config or settings files in the usual places, /etc and not found them?
(12-17-2020, 10:03 AM)notpod Wrote: I would like to disable the passcode lock screen. Takes way to long to access the phone and I have zero worries over 3rd party access to the device.
Settings - > Privacy - > Screen Lock
That only seems to adjust the time before the screen locks. It does not turn off the lock screen when waking the phone.
  screen brightness Uturn 1 699 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 663 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 848 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 3,965 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,910 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,178 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 981 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to disable automatic update checks bdicewk 4 2,318 06-12-2022, 08:10 AM
Last Post: bdicewk
  How to return to "home screen" hiddenpotato 7 6,231 03-05-2022, 06:21 AM
Last Post: dcinoz
  Manjaro Welcome screen landscape JohanB89 2 2,179 11-12-2021, 01:13 AM
Last Post: acrux
