Manjaro Issues: Dark Screen & Font size
I download Manjaro KDE Plasma 20.10 last week.   I have two issues I don't have a clue to solve.
!. Pinebook Pro, screen is dark
2. Font size is to small to read or see... increased the font sizes but website size don't change.
Thank you for any assistance you can give me.
My regards,
Let me clarify what I mean by a dark screen.
My computer came with Ubuntu, lighting was not an issue. I download Manjaro KDE Plasma on an extra 64gb eMMC card. The set up of Manjaro went fine. The screen was dark after it booted up and I attempt to use the keys F1 and F2 to brighten up the screen, no luck.
(12-14-2020, 09:51 PM)Sally2 Wrote: Hi,
My regards,
My vision is not very good, and Linux distros overall are still very poor with accessibility issues. Manjaro is very dark and I faced the same problems. In the KDE Plasma Menu (It opens with the Pine Logo key) you need to select System settings. Once the System Settings window has opened, you can select "Global Theme" and with that open you can select the Breeze theme, once applied that will open all windows with a light background.
With that done you can select the "Display settings" which will allow you to change the screen scaling to something easier to read. Personally I pick 1.5. After that is selected you need to restart the computer for the scaling to take effect. It should then restart to an interface that is much lighter and easier to read.
Personally I took my Pinebook Pro up to the local library, where I found a friendly helpful person who was able to work with the default settings.
bill
  Manjaro Sway Theme Broken Eighty8 1 262 03-08-2024, 08:41 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 314 02-18-2024, 08:54 AM
Last Post: 9a3eedi
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,722 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 309 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,082 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,164 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 389 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 861 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,998 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,949 08-21-2023, 09:08 PM
