Just got my Pinecil
Hey all.
I just got my Pinecil.  Immediately hooked it up to PD and tested it.  I'm impressed at how quickly it heats up given the wattage I allocated to it.  (I went into advanced settings and limited it to 15 watts, mostly to compare it to a similar-sized soldering pencil I had lying around.)  I did notice one thing odd though.  I didn't use it for very long (just long enough to dip the tip in some tinning compound and clean it), but the space around the "+" button seemed to get noticeably warm.  Not burning hot, mind you, but given that the housing is made out of plastic, it got warm enough to make me wonder how hot the components underneath were getting.  Anyone else noticed this?  Should I be concerned?
Eric
Lightbulb Pinecil -> Pinegun? Avamander 18 19,788 10-13-2023, 02:25 PM
Last Post: denystify
Exclamation What is this - Pinecil V3? andrea6 2 6,271 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 1,108 09-23-2022, 03:47 AM
  Just got my Pinecil donwynne 1 1,577 04-22-2022, 07:01 AM
Last Post: bbeeast
  Pinecil Broken? skaaq 4 5,935 01-25-2021, 11:28 AM
Last Post: skaaq
  Pinecil stuck in shipping? mbreese 3 4,754 01-07-2021, 07:46 AM
Last Post: moxx
  Pinecil - Tip Disconnected molzy 2 4,534 01-03-2021, 07:21 AM
Last Post: molzy
  Pinecil arrived VaZso 0 2,345 12-28-2020, 10:36 AM
Last Post: VaZso
  Pinecil USB-C compatibility EricL 0 1,950 11-24-2020, 04:31 PM
Last Post: EricL
