Flashing an SD card using Pinebook Pro? Konsole?
(12-06-2020, 01:07 AM)nightranger73 Wrote:
unxz imagefile.img.xz
sudo dd if=imagefile.img of=/dev/mmcblk1 bs=1M status=progress conv=fsync
you can skip the first command if you already have an uncompressed img file
unxz command takes a bit of time and gives you no output so just wait for it to end.
Always double check your SD is mmcblk1 using lsblk since the mmc number may change using other distro
Thank you so much for your response.
So I chose the Manjaro ARM image from https://osdn.net/projects/manjaro-arm/st...07.img.xz/
Intially I tried putting the uncompressed file it into my SD card which is 29.7 GiB in order to decompress it but apparently the uncompressed file was too large for the sd card. So I then moved it to the desktop and on Konsole I CD into the desktop. I then ran the first command: unxz Manjaro-ARM-plasma-mobile-dev-pinephon
e-201107.img.xz
The file was able to decompress from here I was completely lost because it was in the desktop and not the SD card so I tried moving the uncompressed image from the desktop to the SD card manually via a drag and drop and got this error
Cannot transfer ‘file:///run/media/sanjevr/6534-6132/Manjaro-ARM-plasma-mobile-dev-pinephone-201107.img’ because it is too large. The destination filesystem only supports files up to 4GiB
So am I just supposed to CD into my SD card and how would I move it from the desktop to the SD card?
I am confused as to where I went wrong? Also how can the img be too large I thought my SD card was 29.7 GiB I don't get it.
RE: Flashing an SD card using Pinebook Pro? Konsole? - by SanjevR - 12-08-2020, 01:56 PM
  install iso from sd card to emmc aular 2 322 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 939 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 2,363 06-11-2023, 12:30 AM
Last Post: AndyM
  trouble flashing eMMC TylerBlackberry 3 1,236 04-13-2023, 05:55 AM
  Device Unable To Read MicroSD Card _radv_ 19 6,133 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 1,472 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 2,017 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,420 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 5,128 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  Flashing gone wrong erg 9 4,389 05-28-2022, 10:52 AM
Last Post: fxc
