Compatible bluetooth headsets?
I paired my Samsung HM1350 headset to my Pinephone but all I get is static sounds out of it. The Samsung headset works fine with my old flip phone. Are there any bluetooth headsets that are known to work with the Pinephone? (It's the Manjaro convergence edition phone running the latest Mobian.)
I played music through a very old Jabra BT3030 some time back, but didn't try it for calls. I wouldn't recommend it though - things have moved on a long way even if you can find one anywhere.
(12-02-2020, 08:39 PM)wibble Wrote: I played music through a very old Jabra BT3030 some time back, but didn't try it for calls. I wouldn't recommend it though - things have moved on a long way even if you can find one anywhere.
It'll be interesting to try it with the bluetooth in the car. (That vehicle is way too old to have built-in bluetooth but I have an adapter for the radio that's known to work with my flip phone.)
  bluetooth wifi bugs aular 6 1,477 08-27-2023, 07:53 AM
Last Post: aular
Question bluetooth speakers and pinephone pro Supervisor 2 1,252 01-30-2023, 09:21 AM
Last Post: Supervisor
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,110 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,392 08-29-2022, 02:46 PM
Last Post: emsyr
  Is the PinePhone compatible with UHS-II or UHS-I Micro SD? 5432h90asfd 5 6,596 09-20-2020, 03:19 PM
Last Post: bitnick
  2.4 GHz WiFi bandwidth reduced 50% when Bluetooth enabled jrobin28260 0 1,765 07-22-2020, 10:05 AM
Last Post: jrobin28260
