Python3-yoyo errors
I installed Mobian to the emmc on my pinephone.  After resizing the partition on it's first boot, I decided to do a full system upgrade with
sudo apt update && sudo apt upgrade
Unfortunately, I encountered an error with dpkg trying to unpack python3-yoyo.
I am unsure of where to look to find more information about this error as a Google search doesn't bring up any results, so any help would be greatly appreciated.
There was an upgrade problem a while back with yoyo: did you install the latest nightly? (Shouldn't be a problem with a nightly since 20201113)
I used the Mobian installer to install Mobian to the emmc. I will download the newest nightly build and try from there.
The nightly build solved the problem with python3-yoyo.  Thank you for the help.
This solved it for me:
sudo rm -rf /var/lib/dpkg/info/python3-yoyo-migrations.* && sudo apt autoremove && sudo apt-get dist-upgrade -y
  Errors when start the system kubussz 2 562 11-21-2023, 11:07 AM
Last Post: kubussz
  Is there a list of software/Hardware errors Franze_m 6 5,162 02-24-2021, 12:07 PM
  Yoyo interefering with apt upgrade Hiraghm 3 3,781 10-11-2020, 11:12 PM
Last Post: ergo owl
