Screen Game changer: gsettings set sm.puri.phoc scale-to-fit true
Applications now fit the screen ...well putty does...so does wireshark...
The command is ran in terminal without sudo too...I did it via ssh and it took
See pic for solution source
Unrelated yet in the vicinity the solution is not intuitive, where are the docs or the source for such Manjaro mobile configuration settings/issues?
I found changing the UI scale from 2 to1.5 helps a ton
owo notices your distro.
(11-26-2020, 09:54 PM)dallytaur Wrote: I found changing the UI scale from 2 to1.5 helps a ton
Where do you change the UI scale?   How did you find it or is part of overall configuration items?
Using sudo, edit:
/usr/share/phosh/phoc.ini
and change the top value from 2 to 1.5 then run:
sudo systemctl restart phosh
to view the changes. I personally found the scaling to be sufficient at 2.
Using sudo, edit:
The scaling help with desktop app. like chromium where the UI is too smooshed and some of the buttons are missing.
  screen brightness Uturn 1 712 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 670 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 859 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 4,022 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,938 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,223 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 998 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 6,304 03-05-2022, 06:21 AM
Last Post: dcinoz
  Manjaro Welcome screen landscape JohanB89 2 2,208 11-12-2021, 01:13 AM
Last Post: acrux
  KDE Plasma Mobile screen scaling Uturn 1 1,824 10-29-2021, 06:59 AM
Last Post: Uturn
