Pinebook Pro and usb bus-powered drives
One thing to keep in mind with the PBP and other SBC-based devices is that power for usb powered accessories is limited. This can become more of an issue if you have installed an nvme drive internally.  There is only so much power to go around.  I like to rip CD's to FLAC and have found there is not enough power on the usb bus to power my external optical drive.  I purchased a cheap externally powered optical drive off of Amazon, which should remedy the issue.  Will let y'all know how it goes.
(11-23-2020, 04:23 PM)qchapter1 Wrote: One thing to keep in mind with the PBP and other SBC-based devices is that power for usb powered accessories is limited. This can become more of an issue if you have installed an nvme drive internally.  There is only so much power to go around.  I like to rip CD's to FLAC and have found there is not enough power on the usb bus to power my external optical drive.  I purchased a cheap externally powered optical drive off of Amazon, which should remedy the issue.  Will let y'all know how it goes.
You can also solve it with a powered USB hub.
https://youtu.be/JkvDTGm3VYY
Thanks jiyong, didn't even think about a powered hub. That's a great option.
  looking to buy one pinebook pro (mainland China) duanduan 3 1,905 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 300 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 238 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 227 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 167 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 554 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 618 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,222 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 1,998 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,123 11-20-2023, 06:22 PM
