My PBP does not boot anymore. Please help
I am using the PBP with Manjaro KDE Plasma 20.10 (the last update).
I was following the steps from this forum page in order to be able to use the suspend to ram feature: https://forum.pine64.org/showthread.php?tid=10250
All the steps went fine, but after reboot the green light appears imediately an nothing else happens.
Can you please help?
1. Was I doing anything wrong? I have a 128GB emmc installed.
2. How can I recover from this state?
Try a bootable sd card.  If the u-boot in eMMC is still good, it should boot from that.
If the eMMC u-boot is bad, then you'll need to open it up and move the eMMC switch, then it should be able to boot from SD.
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,204 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,224 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,965 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 4,406 06-02-2023, 01:32 PM
  Tow Boot install help Paulie420 7 3,746 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 1,971 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 1,064 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,514 08-18-2022, 11:47 AM
Last Post: Bemo
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 10,266 05-12-2022, 05:00 AM
Last Post: Pino64
  Broken eMMC boot annahellrothsparent 3 2,444 04-28-2022, 07:31 AM
