Can the developer's of the pinephone consider selling SD card with different OS pre-i
Have the developer's of the pinephone considered selling the different OS pre-installed on SD Cards configured for the pinephone?
Another point to consider is a pre-written app for linux where the user can use a GUI to install the different OS onto the SD Card or internal Pinephone Storage of the pinephone (emmc storage). This would make it easier for new inexperienced users like myself to do this more easier.
You simply download the operating system you want to your computer,
then use 'Balena Etcher' to flash that system to your sd card.
There are new releases everyday of some operating systems.
Pine builds the hardware,
   The different operating system Developers offer their software online to be downloaded.
These are all separate entities.  The Software Developers are not employed by Pine.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Some people are finding Balena Etcher on Windows is producing unbootable sd cards. I don't have Windows to check for better alternatives.
Consider how many times they have to update their SD cards with the latest builds.
Maybe it's doable with stable builds of each distribution, but at this moment there is none.
(11-19-2020, 02:11 PM)sportsbkrider Wrote: Have the developer's of the pinephone considered selling the different OS pre-installed on SD Cards configured for the pinephone?
Maybe a forum member would be willing to download and flash an sd card for you.
BUT,  if downloading an operating system and flashing that to an sd card is beyond what you can do (?)
              Perhaps a Pine phone would not be a good fit for you.. ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  install iso from sd card to emmc aular 2 172 03-11-2024, 10:24 PM
  PinePhone - boot from microSD laserpyramid 5 306 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 105,162 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,525 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 464 01-19-2024, 01:29 PM
Last Post: fxc
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 792 01-09-2024, 07:02 PM
Last Post: britelite
  Multiple issues with the Pinephone MTXP 12 1,940 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 384 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,480 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,608 12-04-2023, 02:14 AM
Last Post: Peter Gamma
