Can internal PinePhone firmware be compromised?
Perhaps a stupid question. Is there any firmware in PinePhone which could be compromised by the OS? For example, I heard that a compromised OS on a laptop can compromise BIOS, which makes the computer insecure without recurse (and you won't know it unless you have Anti Evil Maid).
Let's say I install some untrusted OS on the eMMC, use it, then wipe it. After that I boot from a trusted microSD, can I be sure that I am not compromised?
I am also thinking about such a use case: I have untrusted OS on the eMMC, where I collect all the viruses I want. When I need to do something security-critical (e.g., open my email), I insert a microSD with a bootable trusted OS, use it and then remove the microSD again returning to the initial untrusted OS. Would such access to the email be secure?
All software available to the public can be compromised, and unless it's something almost nobody uses, all software will be compromised at some point in time.
Privacy, security, and freedom is never ethernal, and it's never a gift.
Both the consumer and developer have to fight for it forever.
The firmware in the Quectel modem can be changed and therefore it can also be corrupted.
I have not heard of any way how the bootloader could be compromised?
If that is not the case, eMMC always can be cleaned.
(11-18-2020, 02:16 PM)fsflover Wrote: Let's say I install some untrusted OS on the eMMC, use it, then wipe it. After that I boot from a trusted microSD, can I be sure that I am not compromised?
Unlike regular computers, ARM systems have all the bios-y info stored on the emmc/sdcard, as @LinAdmin2 pointed out the modem has it's own firmware,  but that can be reflashed as well.
Would there be a way to lock down modem firmware with a dip switch seems like a major target
owo notices your distro.
Wrong;
The ARM system must have some initial loader to start reading from eMMc or sd.card.
Wrong;
I'm led to believe boot is hard coded into the chip. The rest is on emmc/sdcard.
https://linux-sunxi.org/Pine64#Boot_sequence
https://linux-sunxi.org/BROM#A64
  pinephone virtual keyboard aular 4 297 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 198 04-02-2024, 11:50 AM
  PinePhone - boot from microSD laserpyramid 5 469 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 107,911 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,713 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 571 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,253 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 471 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,630 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,834 12-04-2023, 02:14 AM
Last Post: Peter Gamma
