Is there a temperature sensor on Pine?
Thanks longsleep, your post is very very interesting. I did not think that 45°C could be a normal temperature
(06-05-2016, 03:31 AM)longsleep Wrote: A heatsink greatly improves heat dissipation for normal short burst work loads or in bad thermal environments (eg. inside a case with no air flow). Without a fan, the heat sink will reach its maximum dissipation capability after a couple of minutes of constant load  (the exact time depends on the heat sink quality, ambient temperature and air flow).
So, do you think heatsink is a good buy?
So, if the micro-USB connector doesn't give the best power feed, what is the best setup? Is it better to use a battery constantly recharging via the Micro-USB?
(06-13-2016, 03:58 PM)simonritchie Wrote: So, if the micro-USB connector doesn't give the best power feed, what is the best setup?  Is it better to use a battery constantly recharging via the Micro-USB?
Best option is power via the DC IN pins on the euler bus.
This document shows all the pin assignments (pinouts) of the Pine64 board.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,508 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 553 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 3,775 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,865 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,255 02-09-2021, 12:17 AM
Question A64 TDP / max CPU temperature grobbs 3 4,670 02-02-2021, 04:35 AM
Last Post: barray
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,424 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,622 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 2,733 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,205 12-02-2019, 09:36 PM
Last Post: netHolio
