Reset Password Last Night, Now I can't login
I reset the password to a word using sudo password and I used a word, not numbers. Now when I log into my phone, I see the number pad to enter the password but I just realized that the number pad doesn't have any letters on it. Is there a picture that shows where the letters would be? I tried looking at my Samsung phone but I still get a password Login error.
You need ssh connection using wifi or serial cable to reset passwd
(11-17-2020, 04:50 AM)Phydoux Wrote: I reset the password to a word using sudo password and I used a word, not numbers. Now when I log into my phone, I see the number pad to enter the password but I just realized that the number pad doesn't have any letters on it. Is there a picture that shows where the letters would be? I tried looking at my Samsung phone but I still get a password Login error.
it is not possible to use an alphanumeric password to log in phosh.
you'll have to change the password to digits again with ssh.
what I personaly do is use the manjaro user only for the graphical interface. when I ssh to the phone, I use another user with a strong password.
of course, a digit only password being easyier to bruteforce, you should not allow the manjaro user to login through ssh.
(11-17-2020, 07:20 AM)nightranger73 Wrote: You need ssh connection using wifi or serial cable to reset passwd
[quote pid='83602' dateline='1605619246']
How do I do this if I can't connect to the phone to get the IP address? It's connected to my HotSpot on my other cell phone. I just got the phone and was trying to get it ready before my sim card arrives.
[/quote]
depending on your router, it may respond to manjaro-arm
ssh manjaro@manjaro-arm
otherwise, you can probably find its ip address on you router configuration page.
and in last resort, you can chroot with jumpdrive.
[/quote]
Looks like I'll have to go the chroot route. Can I use a regular Arch Linux USB stick to boot the phone or do I need the Manjaro-ARM for that? Also, do I just turn the phone on with it connected to the adapter with the USB drive in it or do I need to hold the volume button or anything like that? I tried doing an emergency boot by holding the volume up button and turning it on but it just booted regularly.
just flash an sdcard with jumpdrive, and boot it.
then, plug your phone on your computer, and you should be able to see both the emmc and the sdcard.
mount the manjaro partition, and chroot to it.
to check which partition is which, you can try to get the information with blkid.
LABEL should be ROOT_MNJRO
example:
sudo blkid /dev/mmcblk2p2
/dev/mmcblk2p2: LABEL="ROOT_MNJRO" UUID="d5cca115-e24b-4d0b-a397-47cf7f8cb4d1" BLOCK_SIZE="4096" TYPE="f2fs" PARTUUID="fb7df8c4-02"
  New phone, KDE desktop settings reset on reboot zzb0 2 1,757 10-15-2023, 10:19 PM
  What is the easiest way to login? shengchieh 2 1,118 01-21-2023, 07:08 PM
  Hard reset Nootaku 1 1,515 01-21-2023, 06:56 PM
  Setup/settings lost on reset/reboot GrapeJuice 0 1,009 02-10-2022, 05:40 AM
Last Post: GrapeJuice
  How to remove Manjaro Phosh lock screen password? Avisando 4 3,925 10-28-2021, 04:20 AM
Last Post: Avisando
  phosh 11 stops dead at login after update Rainer 2 2,381 07-22-2021, 04:36 AM
Last Post: mouffa
  Can't login after reboot dpli 2 2,491 05-12-2021, 03:51 AM
Last Post: dpli
  Passcode to login to Manjaro on Pinephone livanti21 4 11,909 10-01-2020, 07:29 AM
Last Post: Doodenheimer
