sd card reader is smoking?
(11-18-2020, 12:10 PM)Nick_dnepr Wrote: okay, i have just disassembled my pinephone. i can't detect any shortages, there is just a metal plate above the contacts. i will assemble it back and try a couple of other cards
(11-16-2020, 10:39 PM)barray Wrote: Glad to hear!
Hopefully you are able to get to the bottom of this. Probably worth documenting exactly what happened to release smoke so that the whole community and future devices can potentially benefit.
I removed the back cover, inserted sd card #1, very soon found out it is smoking, removed battery. inserted sd card #2, powered it on, it worked fine. removed the battery, inserted sd card #1, powered it on, burnt my finger because it was extremely hot, removed the battery again. then i tried to plug sd card #1 into my pc through usb card reader and it worked just fine.
I would not have dared to insert that #1 a 2nd time Blush
If #1 gets hot in phone and works in PC then I would guess that the PC is in better shape to adapt signal levels to what the card requires.
Obviously the complex handshake protocols between card and the interface in phone do not work as expected.
I suggest you try a few other (small low cost) cards in the phone and check if any one of them gets hot. When not, your #1 looks partially defective and I would no longer use it in the PC either.
If another card gets hot in the phone then I guess that the phone's hardware is defective. In this case, both cards that became hot, are in danger to be damaged, and I would no longer trust them.
I assembled phone back and tested a couple of cards: #2 stil works fine. #3, which is identical to #1 is also functional. After a couple of tests on different devices, i tried to insert "the hot" #1 card. and now it works fine. it's readable and usable. probably i had accidantly shorted somecthing during my first try (i  don't really know how i managed to), but, fortunately, my phone survived it without suffering any damage
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 23,833 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,429 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 1,999 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,224 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 1,808 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 6,521 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 3,973 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Strange SD Card Problems anhilde 7 6,372 02-21-2021, 07:52 AM
  Fastest SD card happybot-4678 9 8,549 02-20-2021, 01:08 AM
Last Post: dsimic
  SDXC card prevents power on hiimtye 8 6,911 12-10-2020, 12:23 PM
Last Post: thatwaschrislee
