After todays upgrade unlock screen does not work anymore
(11-13-2020, 12:57 AM)kern707 Wrote: I have gotten yesterday in the afternoon, in the "Software" application of the PinePhone, a notification that an "OS Update" is available. I did not tap on "download" yet.
Is that the said update that bricks the phone?
One thing that I do not understand, why there is no details? also with the first Update that I have made (which was very positive!), all that was written was something like "performance and security updates", I think it will be useful that some additional details will be added to the update description, especially when this is an OS update (which core libs are being updated? kernel? from which version number to what? etc..)
you can check for updates with checkupdates.
and yes now it is safe to update.
the package that used to break the phone was phoc version 0.4.4+4+ga5bdd63-1
it have been fixed in 0.4.4+4+ga5bdd63-3
Sweet! thanks for the info! I will now try to update.
(11-13-2020, 02:23 AM)ak42 Wrote: you can check for updates with checkupdates.
checkupdates in my version (5.9.1-9-MANJARO-ARM #1 SMP Wed Nov 4) results with the error message:
have you tried installing fakeroot ?
sudo pacman -S fakeroot
Thank you, this solved my problem!
  screen brightness Uturn 1 712 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 670 07-07-2023, 09:38 AM
Last Post: Uturn
  new PinePhone upgrade issue WhiteHexagon 5 1,804 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Backup and Home Screen Tinkering on Phosh jakfish 0 858 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 4,019 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,935 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,222 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 998 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 6,301 03-05-2022, 06:21 AM
Last Post: dcinoz
  Manjaro Welcome screen landscape JohanB89 2 2,207 11-12-2021, 01:13 AM
Last Post: acrux
