[SOLVED] bluetooth issues
I was facing bluetooth issues with the latest manjaro phosh image.
bluetoothctl only displayed
No default controller available
dmesg would give the following error:
[   11.573943] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723cs_xx_fw.bin
[   11.595217] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723cs_xx_config-pinephone.bin
[   11.602883] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723cs_xx_config-pinephone.bin failed with error -2
the file  rtl8723cs_xx_config-pinephone.bin was missing in /usr/lib/firmware/rtl_bt/
but there was a rtl8723cs_xx_config-pinebook.bin
I just copied it and renamed it as the required one, rebooted, and bluetooth worked.
Just sharing in case someone else faced the problem..
  Issues with PinePhone Pro Glenn 1 1,248 07-28-2022, 11:56 AM
Last Post: Airdale
Question New user/phone here - initial update issues sexywheat 2 1,715 06-29-2022, 04:27 PM
Last Post: sexywheat
  [Solved] How I got fsck.f2fs to get unstuck and fix not booting PP gab 1 2,297 02-08-2022, 01:35 PM
Last Post: gab
  Problems with audio via bluetooth connect to car zkajdan 0 992 01-15-2022, 12:35 PM
Last Post: zkajdan
  Bluetooth low energy & ANT+ sports sensors Pinephone distro? Peter Gamma 34 49,374 12-08-2021, 04:50 AM
Last Post: thibaultmol
  bluetooth connection to car multimedia interface problems (no sound) zkajdan 0 1,031 10-29-2021, 01:34 AM
Last Post: zkajdan
  deep sleep issues on multiple distros discogribbs 0 1,205 08-19-2021, 08:52 PM
Last Post: discogribbs
  [solved]no more call received [ModemManager, QMI protocol error] alexandre 1 2,835 04-19-2021, 05:57 AM
Last Post: alexandre
  Scaling Issues With Various Programs on Pinephone publiclewdness 3 4,373 11-22-2020, 07:29 PM
Last Post: publiclewdness
  [SOLVED] Brand new pinephone bricked almost immediately out of box... Cree 9 13,595 07-31-2020, 01:51 PM
Last Post: wibble
