Making Consoles Great Again
The console is dead, especially on a phone.  Right?  It is Halloween so lets bring it back to life
One of the things I want to have is the ability to keep a small BT keyboard around and be able to remote admin, instead of always having a laptop on hand.  Well none of the graphical terminals work well on PinePhone so what to do?  How about the console?  With a little attention it can be made usable!  That pic is ssh into a remote system and editing a PHP file with vim.
Install the kbd package first.  Then we need to make the text readable and landscape mode.  Easy enough.
Modify /etc/init.d/consolefont:
# Added 201031 by jmorris@beau.org to get a more usable
# console on a PinePhone.  (Using a BT keyboard)
# Also added the extraparam in the setfont invocation below.
echo 1 >/sys/devices/virtual/graphics/fbcon/rotate_all
[ -d /dev/vc ] && ttydev=/dev/vc/
x=1
while [ $x -le $ttyn ]; do
# Added extraparam to get a more readable spacing with the -h option
if ! setfont $consolefont $extraparam $param -C $ttydev$x >/dev/null; then
Then /etc/conf.d/consolefont:
consolefont="sun12x22.psfu.gz"
extraparam="-h28"
Finally, enable the consolefont service:
rc-update add consolefont boot
This gets you an almost perfect 120x25 terminal window without any loss of vertical space to multiple bars of unneeded cruft.  Alt-F7 gets back to the phone interface.
  Making Calls Zweitaktmotor 11 15,564 07-19-2020, 04:59 AM
Last Post: PureTryOut
