Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress.
(11-07-2020, 12:45 PM)plainenough Wrote:
(11-07-2020, 11:34 AM)KNERD Wrote: According to their official link to the image, there has been no new image posted within the past six months.
https://ci.ubports.com/job/rootfs/job/rootfs-pinephone/
That is just an old job check here.
https://ci.ubports.com/job/rootfs/job/ro...stemimage/
Thanks for that update. I tried it on my Manjaro CE, and I must say the experience is much nice than the Manjaro one. Though, I am sure I need to update the image of Majaro. The Manjaro one which was installed on the phone did not even have a camera application, nor did it automatically setup the APN connection like the UBPorts did. Though Manjaro comes with Telegram Messenger which I use.
I was not able to get any of these newer images running.
My posting in the ubports forum til now got no answer
https://forums.ubports.com/topic/5140/pr...one-builds
Can anybody please help me how to get a running version???
I used Etcher to put it on SD card, and it booted right it. UBPorts is quite nice.
Have you tried using the Bmaptools method?  I can't get dd or Etcher to write the image successfully but `bmaptool copy <utimage.xz> /dev/sdX` works well.
(11-17-2020, 02:05 PM)ikidd Wrote: I was not able to get any of these newer images running.
If you are having problem with Etcher, then you need to look at the SD cards you are using. Yeah, it works that good.
Update on the pinephone on the Q&A
  ADB support on Pinephone Sumwun 3 786 09-27-2023, 04:04 PM
Last Post: Sumwun
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 5,644 06-26-2023, 07:50 AM
Last Post: gregb49
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 701 05-12-2023, 05:06 AM
Last Post: c3l@
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 2,789 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 4,863 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  Images won't boot past pinephone logo remington_luger 9 9,534 08-22-2021, 09:56 AM
Last Post: remington_luger
  GhostCloud workaround for PinePhone mark1250 1 3,155 08-12-2021, 02:53 AM
Last Post: Uturn
  online accounts in UBports Uturn 2 4,146 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 9,495 03-13-2021, 01:51 PM
Last Post: KNERD
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 3,004 11-27-2020, 07:40 PM
Last Post: piney-tim
