Porting lora (meshtastic) to Pinetab, some questions...
Bug
Hi ya'll,
So I just received my pinetab (with an alpha version of the Lora radio module).  I'm eager to port meshtastic to your slick board but I admit I haven't been following pinetab development closely.
I'm reasonably experienced with linux driver development (though not this year) and I think I can handle that part, but I have some questions on distribution choice etc...  Any advice would be appreciated:
* What OS distribution should I target initially? - I assume the development branch of the "ubuntu touch" that came preinstalled on the tablet?
* I will need to build and distribute an (improved) version of the CS341 driver for the USB/SPI chip used in this radio.  Where would be best to provide that for others (a .deb?)
My general current (crummy) plan is here.
@geeksville Sounds good! I would vote for Mobian, I guess most of the PineTab users use it. Good luck with your project!
iiuc the rf95 you intend to use is external hw , so i guess the pinephone hw is missing some crucial bit to suffice on its own?
after reading an rf965 datasheet i guess the point is the extreme sensitivity of that modem
  PineTab 2 login screen rotation fix chzbacon 11 3,950 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,041 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 756 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,180 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,483 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 29,530 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 682 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 145,926 04-26-2022, 11:58 AM
Last Post: thomzane
  Xmonad on PineTab Telefza 0 1,806 06-24-2021, 04:04 AM
Last Post: Telefza
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 4,084 04-30-2021, 06:52 AM
Last Post: thomzane
