Pinebook pro crashing when put to sleep?? [Manjaro]
Hijacking as well to say that downgrading from 5.9 to 5.8 fixed a bunch of other issues for me besides sleep, around memory/swap. In case anyone is having similar issues with freezes around swapping and memory not being released properly after terminating a process
I confirm severe kernel memory management problems on 5.9 and 5.10-rc's.
As of now (5.9.3 and 5.10-rc2) are unusable.
EDIT:
I just compiled 5.9.4 - same situation - unusable.
EDIT 2:
They released 5.9.5 shortly after 5.9.4. Compiled it and it has no leak. It was panfrost leaking.
There is also a bug in Mutter7, causing gdm to crash when you return from sleep or even from lockscreen
Sleep is often problematic, I haven't really tried on the PBP.  I try to not close the lid, I grab the left side and stand it up on the floor to put it down.  With the screen and keyboard being at right angles it stands up quite nicely on its side.
I haven't bothered to play with it because getting my SSD to boot is more important, but I wonder if a dedicated sleep partition would  work better than a file.  4 GB isn't that much space to give up, even on an SD.  Using a swap file doesn't seem like it would work very well if something happens to be swapped out when you start to go into sleep.  Swap and sleep will run into each other and I don't think either checks for the other.  I set up a 10 GB swap partition on my SSD that seems to work fine.
  Debian on Pinebook Pro u974615 7 869 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 264 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,466 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,724 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 309 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,089 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,169 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,126 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 390 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,195 11-23-2023, 07:37 AM
