Unable to connect to Wi-Fi with 802.11r enabled
So I just got my Pinebook Pro ANSI in and right off the bat I found I was having trouble connecting to Wi-Fi under Manjaro. It refused to connect, and kept asking for the password again and again.
I then remembered I had 802.11r Fast Transition enabled across my APs (under OpenWRT). When I disabled it on one of them, my Pinebook was able to connect. Turning it back on kicks it off the network.
Is this a known issue? I haven't experienced an issue with any of my other wireless devices. I'd like to keep it enabled if at all possible. A lot of people in my home make use of Wi-Fi calling, and FT helps with dropouts.
Thanks! Smile
I had to turn off 802.11r in OpenWRT as well. This was when I got my PBP early in the year. I have not tried since.
  Unable to Boot anything (emmc or SDcard) line72 5 1,903 01-17-2023, 12:07 PM
Last Post: nfms
  Unable to boot from emmc after flashing it rfm83 3 1,684 11-08-2022, 10:59 PM
Last Post: rfm83
  PInebook not booting with eMMC enabled aragaer 4 4,103 10-25-2021, 09:11 PM
  cannot boot SD card : "unable to select a mode" alchemist 0 2,081 06-18-2021, 02:03 AM
Last Post: alchemist
  I'm unable to open downloaded programs hayduke 9 7,729 06-09-2021, 02:34 PM
Last Post: jiyong
  Can the Activity LED be enabled under Manjaro? Cralex 1 2,477 01-07-2021, 12:36 AM
Last Post: rimaille
Question cannot connect to wireless - Pine64/Manjaro markbesw 0 1,837 12-16-2020, 05:11 PM
Last Post: markbesw
  Problem with Pinebook Pro unable to read mmc1 murda 2 3,442 11-22-2020, 03:08 PM
  Another Newb Unable to Boot From microSD JimmyJazz1971 3 3,955 10-26-2020, 03:48 AM
Last Post: JimmyJazz1971
  Pinebook Pro won't connect to wifi Samuel Venable 4 5,215 09-22-2020, 12:26 AM
Last Post: bcnaz
