Ribbon cable routing
Got my camera, unboxed it, noticed one issue right away, the sensor(?) ribbon cable was not connected, which is easy enough to re-plug.  I'm guessing that manipulations of the wifi antenna (brown piece in the middle of first pic) made it come loose.  It's a rotate-to-close connector on the rear board, with the cable positioned in a way that any significant pressure would be towards the open position.
Will give it a whirl tonight to see how things work.
