How to edit & compile apps for PBP
How can I install apps such as bitwarden, ElectronMail and ProtonMail Bridge? They provide the code which appears to be targeted also for linux, so I have hope it should work on my Manjaro PBP. Protonmail bridge also provides the PKGBUILD. The only problem is that they probably not designed to work on aarch64.
Is there a way to modify them to work on PBP Manjaro?
I tried installing bitwarden via AUR but it's dependency on electron seems to break it. I couldn't find any way to change that electron version. In other instances of package install via AUR (say in the case of signal desktop) I get the error if incompatible architecture ("...not available for the 'aarch64'...").
Thank you! I really appreciate the help.
  Running Windows apps on PBP moonwalkers 0 2,445 03-03-2021, 12:33 AM
Last Post: moonwalkers
