Private Internet Access VPN on Pinebook Pro
(10-25-2020, 04:34 PM)bastafari Wrote:
(10-25-2020, 10:14 AM)silverine Wrote: Bastafari,
I am looking to set up my expressvpn on my new pinebook pro running the pre loaded manjaro os.  I'd be very interested in how you achieved it, but the link you provided doesn't seem to be working for me.  Could you share the process in some other way?  Many thanks in advance!
Click the hyper link in the post by me before you. It takes you to a guide I made. It may or may not apply to you but give a shot.
Sent from my OnePlus 7 Pro using Tapatalk
I'm still having no luck with that link (404 page not found error), could you try re-posting it maybe?  I'd be very grateful.
Nevermind, the issue must have been on my end. I tried it on another computer and the link worked. I was able to get the VPN set up. Thanks!
(10-27-2020, 10:53 AM)silverine Wrote: Nevermind, the issue must have been on my end. I tried it on another computer and the link worked. I was able to get the VPN set up. Thanks!
Awesome.
(10-23-2020, 11:16 AM)11Eleven Wrote: Greetings,
Do any of you use VPN's on your pinebook pro?  I tried installing PrivateInternetAccess on mine, but it doesn't want to run.  I was wondering if anybody here had any success with it, or could point me to a suitable alternative.  Also, how would I go about uninstalling it, I'm still presently a noob...
Thanks!
This is for Manjaro OS
You can configure PIA VPN through System settings GUI > Click connections under Network > Click + (add new connection) > select OPENVPN > in VPN (openvpn) tab enter your gateway i.e.
"us-atlanta.privacy.network" , change connection type to password, select your CA Certificate (browse for location of your ca.rsa.2048 cert. Click on advanced > General tab  check box use custom gateway port enter 1198 check box use LZO compression (change to adaptive) > Click security tab change cipher to AES-128-CBC change HMAC Authentication to SHA-1.
Connect to your network then connect to the VPN (picture of a shield) from the toolbar.
Config files download OPENVPN CONFIGURATION FILES (DEFAULT)
https://www.privateinternetaccess.com/he...ovpn-files
  looking to buy one pinebook pro (mainland China) duanduan 3 1,915 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 305 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 240 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 231 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 168 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 558 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 623 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,240 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,001 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,162 11-20-2023, 06:22 PM
