Install postgres
I've tried both the x86 and arm versions I found on the arch-linux wiki and they both gave me an error saying I do not have the correct architecture.  Where can I find a postgres that will work on PBP Manjaro?
Still confused about relationship btw Arch and Manjaro.
AArch64 is the right one.
(10-21-2020, 11:36 AM)Samurai_Crow Wrote: AArch64 is the right one.
I could use more explanation. I downloaded a file from here https://www.postgresql.org/download/linux/#generic
I ran it but then nothing happened but it seems installed. If I type psql it says the DB is not running and there is no UI from which to turn it off or. Are there instructions on how to install it? I can't find anything for arm.
So the way to do it I think, in the off chance anyone else needs this info, is to install it first then go the wiki and follow the instructions. I could not find a one-stop shop.
wiki: https://wiki.archlinux.org/index.php/PostgreSQL
arm: https://archlinuxarm.org/packages/arm/postgresql
ARM is 32-bit ARM. The PineBook Pro is 64-bit ARM which is called AArch64 architecture which isn't compatible with 32 bit Linux.
It installed though, without any errors saying that I was installing the wrong package type. I have failed during installation as it won't start the server, and I cannot delete postgres (to try a reinstall) as it requires a PW which I have not set/does not exist.
Doesn't seem like these would be related to wrong architecture though?
For the package manager?
id ,,, should show you are in sudo group
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,863 08-03-2023, 03:30 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,870 06-01-2023, 10:58 AM
  Use SD to install new OS over pinebook debian Rudy558 9 10,698 09-25-2022, 01:19 AM
Last Post: jackwilson
  MiniConda Install Issues nixyhustle 0 785 09-16-2022, 10:06 PM
Last Post: nixyhustle
  Does anyone know how to install levinsboot on pbp? computerc 0 629 09-05-2022, 03:52 PM
Last Post: computerc
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,414 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  microsoft teams install problem jip 3 3,890 02-17-2021, 09:27 AM
Last Post: pagesix1536
  Install TorBrowser on Pinebook pro 2020 edition BananaPekan 0 2,055 07-30-2020, 04:52 AM
Last Post: BananaPekan
  pip and install Jupyter lab jcj52436999 4 6,429 07-17-2020, 07:04 PM
Last Post: carlosqueso
  Need to install 64-bit Ubuntu rhyde 6 7,606 06-20-2020, 07:44 PM
Last Post: rhyde
