Live boot with persistence?
Lightbulb
Anyone know or have tried creating a live sd with a persistence partition? I am currently running Ubuntu but have booted Mobian a few times. Mobian looks promising. Could this be done similarly to Kali Linux? https://www.kali.org/docs/usb/kali-linux...rsistence/ Thoughts?
I've done a Kali Linux live with persistence partition, it's alright, not that great, the PITA (Pain in the A$$) part is updating it from USB. It took soooo long that I gave up updating it and just run it with what it has.
When you run a brute force attack, it runs pretty slow. If you're going to run Kali, I'd suggest a virtual machine.
But if you want to play around with a USB with persistence it definitely is doable make sure you use a 3.0 USB flash drive.
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 53 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,175 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,611 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,582 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,703 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,089 12-02-2020, 10:29 AM
Last Post: linux123
  Occasional boot toiny 0 2,158 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 4,383 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,472 03-18-2020, 09:42 AM
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 2,338 09-03-2019, 11:57 PM
Last Post: hbaxmann
