just got blocked on wiki.pine64.org
(10-06-2020, 06:39 PM)Dendrocalamus64 Wrote: I don't see them assuming that. The length of block was only 24 hours. The actual reason for blocking was spamming, and when they blocked one account, the spammer just made more from the same IP. The length of block clearly takes into account that the spammer may hop IPs, and that other people may be affected by the block.
Anyway, the block is fixed now.
Here you can see how spammers have been flinging themselves at the wiki:
https://wiki.pine64.org/index.php?title=...:BlockList
https://wiki.pine64.org/index.php?title=...g/newusers
Those screen names are just..... wow.
Sent from my OnePlus 7 Pro using Tapatalk
(10-06-2020, 03:56 PM)dieselnutjob Wrote: Admins should also consider that large companies can have thousands of employees all using the same corporate proxy, and then they all have the same source IP address.
Also it is quite common for mobile connections to be NATed through common IP addresses resulting in the same thing.
There are not enough IPv4 addresses to go around and so assuming that two users on the same IP address is abuse is not a safe assumption.
That's a totally different thing I was not talking about, and you're also incorrect, such IP bans work great against such spam.
  Unable to connect to Pine64 IRC channel due to certificate error? Must-Borrow 1 401 03-10-2024, 02:43 PM
Last Post: Must-Borrow
  Forum Recommendations for Pine64 support? backwoodstech2 0 403 02-04-2024, 07:12 PM
Last Post: backwoodstech2
  Im thinking of building a Pine64 cluster Theirat1991 1 592 01-12-2024, 03:31 AM
  PINE64 EU / Disappointment yoriel79 1 905 12-24-2023, 11:00 PM
Last Post: meekice
  How is it going Pine64.org? Corfromleuven 2 1,078 12-23-2023, 08:15 PM
Last Post: polinkuer12
  Registering my 'nick' on Pine64's IRC network diederik 5 1,178 11-13-2023, 07:36 PM
Last Post: ilebagels
  pine64 opensource dumbphone Phie 13 3,914 08-16-2023, 02:29 PM
Last Post: Phie
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,523 07-24-2023, 03:21 PM
Last Post: Omnios
  My Pine64 Logo Re-Design & Thoughts About A New Logo me! 0 713 04-24-2023, 10:03 PM
Last Post: me!
  Which Pine64 single-board computer has NO on-board wireless modules? peteressive 2 1,305 03-10-2023, 03:35 PM
Last Post: peteressive
