XMonad on Manjaro: is anyone having success?
Hi. I'm using Manjaro on PineBook Pro and I'm trying to install XMonad.
There is no official package for this WM,  and packages from aur cannot be built (Haskell infrastructure for aarch64 in Manjaro seems broken at all).
I installed GHC and Cabal from Nix repository. I even had successfully built XMonad once, but it failed to recompile itself after an update.
I can now build XMonad binary using GHC from Nix, but it won't start because of different versions of glibc in the system and in the nix environment.
Have anyone a success in running XMonad in Arch? If so, what toolchain you used?
  Manjaro Sway Theme Broken Eighty8 1 264 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,724 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 309 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,089 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,169 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 390 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 863 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,999 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,949 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 754 08-18-2023, 02:06 AM
Last Post: juliamenendez
