NVMe-related crashes and instability, plus a solution
(10-13-2020, 08:47 AM)Jojonintendo Wrote: Edit: it works in the end. After setting the kernel parameter it does indeed disable APST, which by default sets the drive to its most powerful state. However after that I can correctly force the PS 2 and have a working system, no longer crashing no matter the workload (been trying to crash it for 2-3 hours now with heavy IO). Even setting it to PS 1 still works, however I don't notice any improvement in responsiveness nor peak performance, so I prefer to stay at ~3W (PS 2) vs 4.2W (PS 1). If the PBP is plugged to the wall, then I can use the PS 0 as much as i want and it doesn't crash, so it definitely was a power issue.
Can you elaborate more on what you did to prevent these crashes?
I've recently installed Samsung SSD 970 EVO Plus 1TB (brand new, up-to-date firmware) in my Pinebook Pro (recent batch, arrived April 2021).
I'm running Manjaro with Linux 5.14.12-1-MANJARO-ARM. From what it looks, the unstable 2 GHz OPP has already been removed upstream and also the override of `max-link-speed` has been removed, resulting in value `1` like it should be.
Yet, unfortunately, the laptop crashes immediately once I even just try to carefully access the SSD (it took several attempts for mkfs, now mount and subsequent ls of the empty drive is enough to cause immediate Oops), with a stack-trace similar to the one in this post (searching for ` arm64_serror_panic` is what brought me here...).
I've tried setting `nvme_core.default_ps_max_latency_us=0` which results in APSTE being disabled. Also that doesn't make any difference when it comes to stability.
I've double checked the hardware connection and it looks quite ok (the flat-cable is slightly too long it seems, I'd say about 0.7mm, but it's fully inserted on both ends and I've used this type of PCB connector before...)
How do you force the drive into a specific power state?
According to `smartctl` the drive has Op state 0 with 7.80W, state 1 with 6.00W and state 2 with 3.40W. As I'm not expecting to get anywhere near the possible performance of the drive with the Pinebook Pro now only supporting PCIe Gen 1, I believe forcing or limiting it into state 2 might be a good idea.
Edit 1: found hints that ribbon cable cleanness might be the issue, cleaned all contacts of both ends as well as the contacts of the M.2 SSD module with isopropanol => situation unchanged.
...don't know if rehashing same old questions on about which nvme (dramless) is lowest on power consumption (idle) for the pbp to post in this thread is appropriate ,
but if anybody has a suggestion ? i was contemplating of acquiring a wd blue 550/750 in 500g ,hynix Gold P31 1TB/500g or a Patriot P300 in 500g ,they are all gen3
the best deal I've seen is with the wd blue 550 ($43 us) but read some horrible stats on idle performance
even with ps2 under 2w in the wiki post.
(12-08-2021, 11:04 PM)josmo Wrote: ...don't know if rehashing same old questions on about which nvme (dramless) is lowest on power consumption (idle) for the pbp to post in this thread is appropriate ,
please see the wiki page for noted working nvme ssds https://wiki.pine64.org/wiki/Pinebook_Pr...SSD_drives
Hey thanks, I've been going through that list and been reading about their issues and the rk3399's limitation with nvme drives...just wondered what consensus there is  for the sweet spot for the nvme drive ,like maybe the Crucial P2 500GB
CT500P2SSD8 for an example ?
low power consumption is  most important for me
ps: I finally opted for the hynix Gold P31 ssd pcie nvme 500GB
seems to work nicely with arch and tow-boot Smile
  New Working nVME gilwood 0 155 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,419 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,725 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,038 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,794 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,793 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 2,555 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,631 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 31,449 02-09-2021, 11:32 PM
Last Post: dsimic
  NVME SPI Update not booting SD Card WZ9V 5 6,248 10-18-2020, 08:36 PM
