Trackpad Ghost touches after some time. Poweroff is workaround.
I have issue with trackpad at PBP. After some hours of work it will suddenly register ghost touches ... and one finger is detected as two ... etc.
Power off and on fixes it for some time.
My X11 trackpad settings:
Section "InputClass"
        Driver "synaptics"
        MatchIsTouchpad "on"
        Option "MinSpeed" "0.25"
EndSection
My additional settings via script:
synclient MinSpeed=0.25
synclient FingerLow=30
synclient PalmDetect=1
synclient VertScrollDelta=64
synclient HorizScrollDelta=64
I tried both firmwares for keyboard/trackpad
I tried many other settings of Xserver.
This problem isn't from begin of buy so it may be some misconfig.
Anyone can help me?
Thx,
  Erik.
I had a similar issue, with some discussion here:
https://forum.pine64.org/showthread.php?tid=9856
Although it's with a very different configuration than yours.
(09-29-2020, 03:17 PM)gleachkr Wrote: I had a similar issue, with some discussion here:
Yes it is the same issue as I read your discussion.
I tried really a lot configuration with/without synaptics etc.
I think it is a hw issue. With new manjaro, sleep mode also help me so it is quick fix.
After I received 3rd LCD with problem and now this Sad
Thx for response. I will follow your thread if anyone find solution.
EDIT:
I was thinking about reseting keyboard by usb bus to fix this.
I tried
lsusb
Bus 003 Device 002: ID 258a:001e HAILUCK CO.,LTD USB KEYBOARD
sudo usbreset /dev/bus/usb/003/002
after that keyboard is OK, but trackpad is total weird and need restart PBP.
Can you try it? I will try also go back to older firmware not from community.
@gleachkr
It's been a while since I've experienced the issue (I'm running manjaro, so perhaps their suspend configuration is helping me here), but if I do I'll try the usbreset trick.
Well, I did see the issue again. usbreset did roughly what you said - broke the trackpad until a restart.
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 243 02-17-2024, 07:06 PM
  pinebook pro trackpad randomly stops working chewie 5 5,805 08-10-2021, 04:33 PM
Last Post: chewie
  How to Fix Touch Capacitive Sticker on Pinebook Pro Trackpad? NM_ 4 4,864 12-17-2020, 06:26 AM
  How easy is it to add donor keyboard and trackpad? ENV 3 5,102 11-12-2020, 07:51 AM
Last Post: Kaythe
  If you are experinencing serious trackpad issues Luke 0 2,293 06-30-2020, 12:02 PM
Last Post: Luke
  Trackpad sluggish response ravanh 17 20,031 04-08-2020, 07:52 AM
Last Post: chaoskampf
Question Help: Keyboard and trackpad SPI update utility broke trackpad User 11436 9 8,434 04-03-2020, 06:29 PM
Last Post: petertog
  Trackpad Emulation Der Geist der Maschine 5 5,941 11-24-2019, 10:39 AM
  Trackpad not working for legacy protocols? danielt 0 1,715 11-11-2019, 04:55 AM
Last Post: danielt
