Happy eMMC and SDcard OS usage for Pinebook Pro Newbies...
#41
>But .... shouldn't have "mmcblk1boot0" and "mmcblk1boot1" have shown up as options,
SD cards DON'T have a *blk?boot? section (it is not a partition)
This is due to the controller on emmc drives, boot0 and boot1 (and rpmb) are
sepearate sections (on the same nand), only 4 mB (and 12mB for rpmb)
This is convenient to know which is emmc and which is SD if they are same size
What's the difference between writing to the eMMC module or SD with "flasher" or "etcher" software , vs. writing to the device with dd of=/dev/rld0 or of=/dev/mmcblk2 ?
I have this idea that the OS knows how to flash and etch these devices, and we might be able to treat them like any random access block device, and in fact it appears that people out there are doing exactly that. Possibly the flasher result would be significantly more compact or something?
Conversely, I'd like to be able to copy raw eMMC to SD - for example, boot from a 128Gb SD and dd and compress the 64Gb eMMC. That could then be reinstalled to recover to that state at the time of the copy.
Thanks for any insight into this.
The only difference, etcher checks that the write was correct, this is nearly always redundent
(and does make it less likely that you will make a.... of=wrong.... mistake,, be careful, use lsblk)
About a year ago,, cd to wherever you want the backup to be, maybe a usb stick?
dd if=/dev/emmc bs=1M |gzip > emmc.backup (replace /dev/emmc with correct mmcblkX, maybe bs=4M might be a little smaller)
Do not do this from a booted system, you want /dev, /proc, /run to be empty,,,, ie from a SD or usb boot
  Pinebook Pro Initial Impressions kunger 443 586,741 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,275 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 386 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 294 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 283 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 215 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 656 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 723 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,569 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,200 12-15-2023, 02:11 PM
